- Jun 24, 2021
- 16,061
- Vinyl
- CircuPool RJ-60 Plus
Yeah, I did a rough estimate about how much I've gone through (my recycling bin is overflowing).Liquid chlorine adds salt.
If you found value, you might consider becomming a supporter. We are a 503c, all volunteers and member support keeps the lights on...Appreciate your help @PoolStored throughout this process. Quite eye opening.
I get paid this coming Friday. It's on the "bill" list.If you found value, you might consider becomming a supporter. We are a 503c, all volunteers and member support keeps the lights on...
Become a TFP Supporter
Help Support TFP Trouble Free Pool is run by a dedicated group of volunteers that … Read more…www.troublefreepool.com
You are way overthinking it...but that is OKFC sits at 13 around 630 this evening. (Pump shut off around 600 / 615.
Million dollar question. Should I configure the SWCG in the am to run at a low output or take a sample maybe mid day and see where its at? If the 25% guide is true, then I should be just around 8 even by the end of sunlight tomorrow.
Thoughts?
8 hrs, 10a to 6pm. Give or take.You are way overthinking it...but that is OK
Let your pool be for the day, it will drift down, I suspect to 10 or 9. Perfect for 70 CYA. No need to test during the day (but you will anyway). Letting it go for the day will give you approximate consumption for the day.
What is your current pump schedule (how many hours do you run?) Go to Effects of adding. Figure out with your SWG and pump run time what % output setting you need to add what you lost from tonight to tomorrow night. Use that setting and start it up.
Test again the next night and adjust output from there...
Must say, I'm a bit excited.I'm going to predict that you will end up between 50-65% given the pictures of your pool. It will be lower if you have a cover on during the day. Let's see where you end up.
Adjust the SWCG to add ~2.5ppm higher or lower is fine depending on the granularity of the controls for tomorrow's start. Let er rip! That should get your FC to about 9.5 Tomorrow.Should I adjust the SWCG for 3 or lower or for tomorrow when the pump turns on? Or wait another 24 hrs for a Friday SWCG day.
Wait to do a full PH test tomorrow as well?
Yep, RJ 60, 40% for 8 hrs adds 2.5. Correct usage of the app. A+So, it should run at 40% for a 8 hr pump run time tomorrow.
If I'm doing the app correctly.
First time I popped on the SWCG.Yep, RJ 60, 40% for 8 hrs adds 2.5. Correct usage of the app. A+
Yes, just check in morning that the generate light is on. Your last salt test result if from your drop test, correct?Adjusted the % to 40. I went through the menu options, and it shows the salt level. It was in the 2000s (my last test should 3200 or 3400). Does it take awhile for it to calibrate or come to the real salt level?
Correct. Last checked two days ago.Yes, just check in morning that the generate light is on. Your last salt test result if from your drop test, correct?
duty cycle every 200 minutesIs the procedure for the SWCG to run to a certain point (based upon the %) and then stop? If so, whew.
