I have been SLAMMing (due to failed SWG + inadequate amount of Chlorinating Pucks) without a testkit.. seems to be going ok.. but then my pump became too noisy.. so I am going back to basics and buying a testkit (+replacing my pump & figuring a new SWG Cell)
have a K-2005Complete kit (it literally says Complete on the box) from 2014! It's almost full but I never used it because it was hard to read (colorblind to point I have a color eye test I can't see any of the numbers past the first page (which is basically black and white)).. however I can see colors just not make out shades of them..
What is best recommendation? I did see the TFP Start up XL kit.. I like the idea of the speedstir and the whale brush but if I just replenish the kit I have (plus add the FAS-DPD... and have someone else look at the test results... )
One question is the TF-100 kit, I read that it doesn't require color matching so much.. but then I read it uses same Reagents as Taylor.. confused.
Too many options.. can someone guide me?
Thank you for your help.
