I'm SLAMing my pool. Although it was crystal clear, I noticed my salt cell required higher percentage than normal for this time of year. Ran OCLT @ CYA: ~55. 6.0ppm down to 3.5ppm the next morining. Not good. Started SLAM, target 24ppm. I use the TF-100 test kit.
Question: How accurate is the Chlorine test at 24ppm vs 6ppm. I ask because the 24ppm test (48 drops) seems like it would have a lot more accuracy issues than around 6ppm (12 drops). Example: Last night I started the OCLT and did a series of baseline samples at the same time and had the following variance (in DROPS): 49, 51, 47, 47, 49. I use a mixer. I have the bottle vertical. Let the drops "hang" before going in, about 1 second intervals, fresh chemicals, etc. Is this variance normal? For an OCLT, the result needs to be within 2 drops, but my variance is larger than that (not repeatable).
I'm sure if I was doing this same test at 6ppm, I bet my variance for 5 tests simultaneously would all be within 1 drop.
Right now OCLT continues as this morning, my result was 44 & 44 drops, so definitively different than last night. However, as I get closer to being "done" with the OCLT, I want to "know" that I'm done, not guessing due to variance.
Please advise
Jay
Please advise
Jay
