SLAM levels - effects in readings?
No, only pH.
During a SLAM - we suggest you only test FC until your pool water is crystal clear. Then do a CC test in the morning after an OCLT.
Reactions: southflorida427
No, only pH.
I read that as don’t do a FC test until after the water is clear. :hammer: Of cause what Marty said is don’t bother with the other tests while SLAMing, test and adjust your FC as often as you can during a SLAM. :p
