Attended Pool School over the last week & using PoolMath & newly acquired FAS/DPD chlorine test kit.
Performed 1st SLAM yesterday but failed OCLT. Can there be a "but" on the but?
Yesterday there was no sun with air temp in the 50's. TFP Chart called for 10ppm SLAM & 1 gal of 8.2% bleach. SLAMmed early am. 20 mins later FC:11 ppm. Two hours later (& all thru the day) FC:12. (tri-chlor auto feeder was set to lowest setting during SLAM so this might be reason FC went to 12ppm, not 10ppm) Turned off feeder at 10 pm, did final test at 11 pm and FC was 12ppm. At 6:30 am today, FC:10 ppm so failed OCLT as lost 2 ppm overnite.
TROUBLEMAKERS: Pool is 25 yards from school ball field (all dirt infield) in constant use (recess & midget league 7 days/wk) And our trees are currently dumping pollen, so we are not sure we have dirt/pollen combo or algae, but see small brown piles on liner floor & brown along floor seams.
When we brushed, there were clouds. If algae, wouldn't the chlorine level drop considerably, requiring more bleach, even with auto feeder on at lowest during the SLAM? Today brown spots & brown along the seams are back... so with failed OCLT, I guess time to SLAM again...
Should I assume it's mustard algae & SLAM for that? Or just keep FC at 10ppm SLAM level, brush/test often (& leave auto-feeder off) & see how testing goes today, with another OCLT tonite? Tks!
Current readings:
water temp: 66º
FC: 10
CC: 0
PH - not testing as FC too high, but was 7.6 when SLAMmed yesterday
TA 80
CYA: <30 (Assumed approx 25-28 as dot disappears soon after 30 level) Two bags of Di-Chlor added 5 days ago & tri-chlor auto-feeder both add CYA. Pool opened in the last week & I read that CYA can take time to show up, so I don't want to add CYA just yet IF it's ok to wait a bit on it.
Current readings:
water temp: 66º
FC: 10
CC: 0
TA 80
