- May 26, 2022
- 18
- Vinyl
- Pentair Intellichlor IC-15
I test FC at 6 AM and 9:00 PM if not more every day. Ladder is out. Skimmer and weir doors scrubbed. Is it safe for me to unscrew the scres holding in lights myself? My pool is on day 13 of SLAM. The water and vinyl liner are SOOOO clean! I'm so exhausted! We backwash....could there be something in the sand? I'm nervous about the safety of opening my Pentair up.How often are you testing FC and adding chlorine to get your FC back up to SLAM level?
Have you removed the ladder and cleaned it? Even inside the tubes with a brush? If not, do that.
Do you have a light? Have you removed it and scrubbed behind the light? If not, do that.
Did you check and scrub the skimmers? Did you check the weir doors for algae? If not, do that.
