- Apr 19, 2022
- 67
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I agree but 3 weeks in something seems to be off.NOOOOO. 40 is great from your own testing. PoolStore testing is unreliable.
Every 2 hours but it’s barely dropping below 1 ppm in 24 hours. The whole system is 3 years old.How often are you testing and replacing FC?
You might deep clean the filter.
Deep Cleaning a Sand Filter
This post will walk you through the anatomy of a sand filter, and then provide a video at the end for how to deep clean your sand filter. The filter used in the photos and videos is a Hayward S180T top mount sand filter. The images are of a similar filter. Obviously not all filters are...www.troublefreepool.com
Oh man, 4 weeks. It’s getting old!I am watching intently. I am on week 4 of a slam and not seeing any improvement as well. 2 gals of chlorine a day is getting expensive.
Thoughts on phosphate remover if phosphates are high?
Follow the SLAM Process to the letter.Thoughts on phosphate remover if phosphates are high?
I don’t log them in the system. But yesterdays numbers werePhosphate removers are not going to help.
Can you go into pool math, gear in the upper right, scroll to the bottom and enable sharing with TFP so we can see your logs...
How many OCLTs have your performed where you passed.
After putting in the pool, what are the rest of the instructions? I’ve never used clarifier.This is one of the few times we might recommend a clarifier. HOWEVER, you should use a high quality one. We only recommend Sea klear Chitosan clarifier…might be expensive, but will not cause issues other clarifiers will….
