- Mar 20, 2021
- 158
- Plaster
- CircuPool RJ-60
Okay, so we had gone out of town for a week and a half and I let the chlorine go to nearly zero (I know, I know, lesson learned). There were a couple small (maybe 6”) streaks of yellow on a shady wall and then over near the light housing. My CYA is sitting at 40 so for the last 48 hours I’ve had the chlorine levels up to between 16 and 18. I took the light out of the housing to made sure I brushed well inside. Here is my question…
The pool is 10 feet deep so I can’t be sure but it does look like there is some yellow just around the main drain. I’ve brush it well and vacuumed each day but so I need to get down there and remove the drain cover? If so, how do I do that with the chlorine levels being so high? Is it safe to swim in that?
Second question- after I pass the SLAM, what is the level for mustard algae I need to get it up to for 24 hours?
Thanks in advance.
Thanks in advance.
