- Jun 1, 2018
- 16,109
- Vinyl
- Hayward Aqua Rite (T-15)
Be sure u have checked every nook & cranny - light niches, drain covers, weir door foam - errrywhere, leave no stone unturned. Dead algea was living algea so in order to keep producing dead algae there may be some still alive somewhere & possibly undisturbed. I once had a slam really drag on because i left an algae filled diver toy in the bottom of the pool thinking it was fine because my fc was so high. (I didn’t know it was filled with algea when i made that executive decision)
I removed it & passed all 3 criteria the next day.
Now that you have mostly clear water & the cc’s have lowered you may wanna look into doing the deep clean of the sand filter as mentioned earlier.
Here’s a helpful write up
www.troublefreepool.com
Keep going- you’re almost home!
When u pass ALL 3 end of slam criteria (including no new dead algae) then you can follow w/ the MA protocol for 24 hrs to be on the safe side if u wish. Its not that much more chlorine & worth the peace of mind likely.
Mustard algae usually forms on the shady side of the pool & is often found on walls not just the floor.
Regular algae can be brownish - this leads people to believe they have MA when often they do not. Either way, the treatment is mostly the same except for the extra day of slam & possibly holding a higher target fc level for a while after.
Deep Cleaning a Sand Filter
This post will walk you through the anatomy of a sand filter, and then provide a video at the end for how to deep clean your sand filter. The filter used in the photos and videos is a Hayward S180T top mount sand filter. The images are of a similar filter. Obviously not all filters are...
