Skimmers not pulling enough
I have been opening/closing my inground pool for 15 years. First time I hit this problem at opening. My water seems to be circulating just fine but when I switch off Main Drain to skimmers only I cannot get a good enough prime for the vacuum to work. It does not even fully prime when vacuum hose is not connected. From what I have read it seems I have air in the lines but I do not see any obvious leaks. Any ideas?
You say "skimmers" plural. Do you always vac with more than one skimmer going. I have 3 skimmers and I did not have much luck with my manual vac working well unless I shut off the other 2 skimmers.
Can you control your skimmers individually?
Problem solved! I noticed a VERY slow drip under the connection from pump to valves (about 1 drop a minute). I took it all apart and reconnected each piece using fresh teflon tape on the leaking connector. I now have complete prime and am able to vacuum. Good lesson. Thanks for all of the suggestions. Sometimes you just need to talk through these things with folks that understand. This site is the best.
