Hey TFP Team,
Traced a sizable leak down to my skimmer and found it was from the tile/skimmer junction area. I was easily able to remove the tiles and found a few spots all washed out and some very soft mortar. I ground/dug out all the loose stuff, washed it out and now I've got some fairly large gaps around & behind the skimmer face where water was flowing.
The bottom center of the skimmer front is the main leak/issue. there's at least a half inch of gap behind the plastic flange behind the holes where it's all washed out. Also the top corners have big gaps as well. Ruler went in about 3" in the top left!
I can do the tile work with the mortar & grout as I've done tile work before and they were broken anyway. The question I have is what do I use to fill the gaps/voids to seal it up so it won't leak? I can basically pipe in the thinset mortar everywhere, let that set up, then do the tiles on top but I wasn't sure if there was some other product better than that for sealing/filling the gaps that would be better.
--Pictures below--
Thanks for your help!
Before
Tiles removed, ground down & cleaned up
Bottom center gap - primary leak/issue
Wider bottom view:
Huge hole 3+ inches deep in the top left:
--Pictures below--
Before
Wider bottom view:
