I'm perpetually stuck with a 'Pre-Existing, Non-Conforming' Commercial pool 75x35 feet. Pool lifted & sunk; skimmer boxes need replacement. All four (!) are on the same 75' wall; at least prevailing downwind! Only ONE actually works (skims) at a time; and all have *way* too much epoxy therapy; so replacement is required.
The BIG Question: What is the expected tolerance for keeping boxes skimming uniformly as to HEIGHT Offset across the span? Calls to the Manufacturer (Hay...) has resulted in NO Concrete Measurement. I was told by a nice old pool guy that 1/16th of an inch would be good! This was not covered in my last CPO class; so what do YOU use as a guide (besides lasers??)
Thanks for any info or guidance to same!
-PoolboyJack
-PoolboyJack
