I've got a dual skimmer set up in my pool with in floor cleaning system. Sometimes, the in floor cleaners seem to miss a few spots so I've used a manual vacuum head/hose set up to suck up some areas. Up until last year, I'd just plug up the primary skimmer with a tennis ball and connect the vacuum hose to the other (since it's more centrally located and the 40' hose can reach the entirety of the pool from there).
This year, I tried the same thing for the first time but something is missing/broken from the port I used to plug the vacuum hose into. Instead of a smooth PVC surface to push the hose into, it's female threaded. It seems like some kind of insert came unthreaded and "disappeared". I did have the pool acid washed and media blasted a few months ago, so this is the first time this year I tried to vacuum since.
I'm attaching a picture. Top port is towards the pool, bottom one is the suction to the filter. The red arrow is pointing to where I feel the threads where they weren't before. It seems like there should be something threaded in here to "accept" the vacuum hose. I bought a 1 /12 inch piece of threaded PVC hose to see if would work, but it appears to be too small. Is there something that should be here? If so, what?
