Skimmer or Main Drain
If you have a LOT of debris, you may not want the skimmer on as much. If the debris occludes the skimmer then you can cavitate the pump. If the skimmer continues to flow you will be fine. But if your skimmer might stop up before you are able to dump it, you may have to put more flow on the main drain. Depends on the amount of surface trash / leaves.
