- Oct 10, 2012
- 229
- Plaster
- Hayward Aqua Rite (T-15)
So it seems my pool has a leak. There's wet ground next to the cement not far from the skimmer. Had a pool plumbing company guy come out and take a look. He says usually the leak is at the skimmer. Also had me lower the water level saying that could be part of the problem. I had the water level almost to the top of the skimmer. He said it should be about an 1 1/4" onto the tile. I lowered the water level to see is that was the problem. I had dug a hole where the ground was wet and it was muddy down near the piping and that seemed to have dried out after lowering the water. Filled the hole back up but after a few days the ground is back to being wet. The plumbing guy said I might have to have the tiles reset around the skimmer. Do I need special equipment to test if the skimmer is leaking?
