Pietro167
10
Fort Lauderdale
Hi,
I just found that the skimmer entrance has a small leak that is draining into and around the outside of the skimmer canister. I was able to use dye and found the source per the pic below. What kind of sealant can i use around the trim that can be applied on a wet surface? Or would i need to drain the pool below the skimmer level, let it dry and then apply?
