When I got home a bit ago, my pump would have been running about 5 hours already. There was no pressure or flow. After realeasing air from the filter, it would try to start and drop back down to 0. It turned out I had a stuck skimmer door. I assume from people being in the pool last night with the pump off, I wave hit the door and jammed it,
I've tried taking the skimmer doors off before but didn't like how much stuff would float back in the pool when the pump turned off.
Is having the doors on, worth the risk of possible overheating the pump if a skimmer door stuck closed for possible up to 8 hours when I'm at work?
I'm torn here. Potential pump damage and a loss of circulation and chlorine generation for up to 8 hours vs junk floating back in the pool when the pump turns off.
Thanks
Thanks
