I have a 13,000 gallon saltwater pool with a new IntelliFlo/Pro3 VSF pump. One of the kids' toys got in the skimmer area and partially blocked the water flow. It did not run dry -- just slowed down the water flow and air got into the system.
When I returned home, I stopped the pump, cleared the problem, and then restarted the pump. The pump seems to be functioning normally -- sounds normal and water flow seems normal. Is there a way to tell if the pump is damaged?
I am new to owning a pool. Thanks much for your help.
