My kids leave toys in the pool quite often which we have no issue with. We swim nearly every day. However, I need my pump to run in order to circulate the water for my heat pump. Inevitably, a toy gets caught in the basket or a pool float hinders the flow of water enough that the pump starts to lose its prime family sucking air.
I need something that will allow water to flow into the basket but not allow anything to come into the basket to stop its ability to suck. I found something on Amazon but it was three and a half weeks out on delivery. The Dolphin pool vac does a great job with leaves, dirt, sand, etc.
Question 2. I'd really like my pool pump to suck water from the bottom of my pool. I kind of thought of a way to do it using the pool hoses of an old pool pump powered randomized pool vacuum I used to use. The pump obviously has its own filter basket but we would to be bypassing the skimmer in the basket. Pump is 3/4 horse and flows around 52 gallons per minute. Not sure a simple pool hose in the bottom of the pool attached to the skimmer would be large enough to prevent taxing the pump.
Draw cool water up, send it through the heat pump, and pipe it back in.
