- Apr 15, 2018
- 201
- Vinyl
- Pentair Intellichlor IC-20
Hello TFP'ers : happy fathers day to all.
I have had nothing but the most balanced and outstanding advice from users of this forum, so hence today's question.
I presently have a 3/4HP superflo, single speed pump. It works well, it is 2 yrs old. It is noisy. Especially because my equipment pad is near where we generally sit.
I might look to replace it this year.
My rationale is:
1) will cut down on noise
2) can save a couple hundred dollars a year
3) can circulate pool water more often (and thus chlorinate more often: SWG user & pool has very sunny exposure, thus chlorination is always a balancing act)
to clarify the last point: i presently run my single speed about 12 hrs a day. my city offers off peak discount on electricity. so, weekdays from 7pm-7am is when i get cheap power(aka overnight). and my water circulates then. Weekends, its always cheap so I run it 9am-9pm.
I generally prefer to have the pump on while swimming. but most of us are annoyed by the noise. I am going deaf (no joke) and so it doesn't bother me much
Well probably not going deaf but my hearing is horrible - i actually find this a benefit in my life
ok, getting off topic... sorry.
i want to stick with pentair. note I am in canada and pool use is seasonal: 6 mos a year at best.
here are some questions, but also looking for someone to jump up and tell me something i never thought of yet.
1) how much quieter is a VS pump
2) will i really save 200$ a year? this seems to be what is advertised on average
3) will low pump speeds cause lower pressure (aka will flow switches still work on heater and chlorinator)
4) will low pump speeds and lower pressure still push water through the sand filter
5) what is the difference between the intelliflo and VS superflo? it looks like intelliflo have fancy controllers right at the pump head. but I already have easytouch & screenlogic... is there something else about intelliflo that adds benefit? it's quite a bit more expensive.
6) does my idea about more frequent low speed chlorination make sense? with the pump on more often and longer, I'd produce more chlorine. this might make $$ savings less
ok, thats enough on this for now... not a bad brain dump.
My rationale is:
