Hi everyone,
Long story short, I have a Hayward SP711 sand filter, and in filter mode the sight glass was filling up with water with a constand drip/leak.
Opened up the filter, sure enough the spider gasket was torn. Replaced it, and the leak stopped.
One week later after doing a backwash, the leak is back though not as extreme. I opened up the filter and the spider gasket is in perfect condition, perfectly seated, as far as I can tell. Lubed it up again and closed it up, but it keeps dripping from the sight glass in filter mode.
Weird thing is that it's intermittent. Sometimes it leaks a little bit when I first turn on the filter and then stops shortly after. Other times it leaks for the entire length of time I have my filter on. I put a dry towel under the sight glass to check-- it can range from being bone dry to being sopping wet.
Any ideas why is this happening?
An extra twist-- the sight glass was installed so tightly I'm afraid to remove it with a tool and break it by accident. Clearly the sight glass shouldn't be leaking at all, but the fact that it's leaking in filter mode has me perplexed.
Thanks!
Thanks!
