I bought a house with an in ground pool last year. It has one skimmer and a side wall suction feed to the pump. It also has two returns. When I bought the house the side wall feed was capped off. Last year when I closed the pool I never opened it. This summer when I opened the pool I left it capped. This year I’m closing the pool and I drained the water down so that the water is a few inches below the skimmer and the two returns, but the water is still above the suction feed. I’m wondering if I open up the side wall suction feed now what would be the worst thing to happen? Right now I’m guessing the line is full of antifreeze and water. If the water level drops then I would know if the line is broke. If the water level doesn’t go down, then am I safe in thinking the line is okay? Does the pool pump need to be running to build up pressure in the line to get the water to leak if the line is broken?
Thanks in advance for the help.
