Just tested the FC and it’s 22 ppm. The slam target level says FC has to be 10. So I do nothing? And just wait for the FC to get below 10?
Make sure you hit the top right check mark last Aa well when done. My iPhone app I missed that step at the beginningThe calculator keeps defaulting to 6%chlorine instead of 10%. I keep changing it but it logs as 6%.
Mine looks different. Under effects of adding it shows 6%. I change it to 10% but there is no way to save it, no check mark.That is odd. In the top left where you have the lines and bar drop down- effects of adding. What # does it have there ? Mine shows 10 just as example.
