- Jun 24, 2021
- 16,654
- Vinyl
- CircuPool RJ-60 Plus
For the TA test, when the color no longer changes, that is the last drop. Ignore that last drop. 31 drops or 310. That is high. High TA is not really an issue. The only implication is that your pH will rise fairly quickly. The article below will explain a bit. It might be a bit of a pain, as you will need to monitor pH fairly closely. You have a choice. You can simply ignore TA and manage pH by keeping it in the 7s. When pH rises to 8, reduce it to 7.0 to 7.2. When it rises to 8, reduce it again. When TA gets to about 80, stop forcing pH to 7/7.2 and only drop it to 7.8...at TA of 80, pH will be stable between 7.8 to 8.0. As the article indicates, you can accelerate the process by using aeration to raise the pH. This is how it works. Muriatic acid lowers pH and TA. Aeration (or just simply waiting), pH will rise, without raising TA. The trick to rapidly lowering TA is to cycle pH between 7.0 and 7.4 (CO2 outgasses at the highest rate), and create LOTS of VERY tiny bubbles. I built this rig on top of a sump pump. I can lower TA by 10 in 12 hours in a 30K gallon pool.
In either case, TA is a minor worry. Focus on replacing water and the SLAM to get rid of algae. TA and pH come later.
www.troublefreepool.com
Lower Total Alkalinity
A lower Total Alkalinity level can help a pool owner stabalize their pH increase. We'll explain how to lower TA with a little help from muriatic acid.
