I bought a house with a pool last fall and ever since reopening it this spring, it's seemed like the filter is barely catching anything. The pump runs and moves water fine, but lots of debris (pollen, small leaves, etc.) comes back out the return ports into the pool (but no sand). The filter pressure is quite low too, usually around 12 psi.
I have a Pentair Tagelus TA60D sand filter. I opened it up today to find out why the water is bypassing the filter and there appears to be no seal between the valve assembly and the standpipe. It looks like the end of the stand pipe just butts up against the bottom of the valve assembly. The pipe ends are chamfered, but I have no idea if they're actually making a seal.
Is there supposed to be some sort of fitting between these parts to ensure a good seal? Is this likely the cause of my debris bypassing the filter?
