Should I raise TA?
emcaston
3
North Louisiana
Using a Taylor Kit, I tested with the following results: FC 4.2, TA 60, pH 7.6, CH 270, CYA 60, NaCl 3200, Temp 75 F, CSI -0.52
I have a Hayward T-15 that runs for 9.5 hours per day at 50%. My replacement cell is brand new. It was installed 3 days ago.
Per Hayward Manual, ideal results are: FC 1-3, TA 80-120, pH 7.2-7.8, CH 200-400, CYA 30-50, NaCl 2700-3400
Should I raise my TA??? Or how should I decide if I need to raise it? Any other recommendations?
JamesW
27,617
I would let the pH get to 7.9 and only lower the pH when it gets to 8.0.
When the pH is 8.0, only lower it to 7.8 or 7.9.
Maybe raise the calcium hardness to 320 ppm.
red-beard
1,394
Houston, TX
Hayward Aqua Rite Pro (T-15)
If you hang out here, you will be "violating" several of those parameters. 60 should be fine if your pH is fairly stable. Mine is 70 and I add about 1 qt of Muriatic Acid a week, when the pH gets to 7.9-8. It drops to about 7.6.
