Say I had enough flow on swcg and heater, but very low flow rate of filtration
Harold,
Well... that would be impossible..
If water is passing through your SWCG and heater, it has to also pass through your filter...
We believe that you should run your pump for a reason, not to meet some mythical turnover number..
The number one reason to run your pump, when you have a SWCG, is to generate the amount of chlorine your pool needs each day. You want to run the pump as slow as you can and still make chlorine.
The number two reason to run your pump is to skim your pool. (Normally, if the SWCG is working, your skimmers are working, but not always, and you might have to increase the pump speed.
There is really no other reason you 'need' to run your pump.. You may want to run it to heat your spa or turn on a waterfall, etc..
Your pool stays clear and sanitized because of the chemicals in the water, not the number times water passes through the filter.. The filter is only there to capture 'junk' that falls into your pool and gets picked up by your skimmer. The filter is not there to keep you from getting algae.. By the time the filter sees any algae, it is too late and you have lost the algae war..
Jim R.
