- Aug 7, 2020
- 142
- Vinyl
- CircuPool RJ-60 Plus
Okay so I guess I might as well wait. Problem is the gas company that installed the gas lines and everything do not install pool equipment. So I’m guessing I’d have to get a plumber/pool installed to install the heater, than have a gas company check pressure and so on?Without your pool running the installation cannot test the heater, check the gas pressures, and commission the heater. If you get a great deal on installation it may cost you a call back once the pool is open.
No.
Why would you want to turn the heater on when the pump is not running? That can damage the heater if it ignites.
See what the installation manual says about heater cool down before the pump is turned off.
And I wouldn’t run the heater without the pump running. Thing is I want to control the heater manually. I don’t want the heater on every time the pump goes on. You know what I mean
