So, I have just installed my first AGP. Initially it was fairly easy but as the family uses it I have been forced to make "improvements". The wife won't use it unless it is warmer.
This led to the installation of a solar heater. However it seems that the most effective use of the solar heater is to set your pump on a short interval timer(SIT). Seemed easy enough...
I purchased a SIT set it up per directions and plugged everything in. It appeared to work at first but at the first stop the GFCI got tripped. Now to be clear there is a GFCI built into the power cord on the pump. This is the GFCI that keeps tripping. Here is my dilemma; How do I keep that from tripping every cycle?
