I recently replaced the heat exchanger in my Hayward H100ID1 1000 BTU natural gas heater I have used for over a year to heat my 850 gallon in-ground spa. Prior to replacement (I was quite sure the exchanger was leaking,) the unit would light automatically only to shut off in ~10 seconds and after igniting 2 or 3 more times, the controller circuit board would offer the 3 flashes on the red status led.
Per the manual, after about an hour in this alarm mode the unit would restart the cycle.
I have jumpered around all sensors in attempt to troubleshoot but no help. The thermostat switch is operable as this allows me to reset the error indicator and initiate a relight sequence by turning dial down and back up to normal setting around 100 F. Likewise the pressure switch is working as it should. I cannot confirm the status of the two overtemp sensors on the exchanger but since water is only 78-80 F they should not be an issue.
Any help around this subject would be appreciated.
