Some background before I get to my question. My SWG is rated to generate 1.45 lbs/day, which for my pool would raise the FC by 8ppm if run 24 hours at 100%. My FC demand is quite low (about .6 ppm/day) even with a relatively low CYA (in 30 to 40 range), and in season I generally run my SWG at 20% for 9 hours daily (which generates .6 ppm to balance out the loss) which keeps my FC in the range of 3 to 4 ppm. My CC is almost never measurable, but every now and then (maybe once or twice a season) it will get just a little pink when I add the DPD reagent. When this happens, I had been adding a pound of dichlor as "shock" (something I bought before I knew better). This approach seems to work OK since I'm not adding dichlor very often, but I would prefer not to use it going forward (particularly since the dichlor I have also has a little copper in it, I suppose presumably to "fight algae").
My question is, it appears I could get the same FC rise from running my SWG at 100% for 12 hours as I get from a pound of dichlor (about 4 ppm). Would this work just as well, or do I really need the "all at once" boost of added chlorine to get the desired result?
