I have 2 sheer descents both 24 inches long so the manufacturer recommendation is to run them at 24 gpm each. I also bought a "Jandy 2888 Ray-Vac Pro Series Energy Element Filter Kit with Gauge" to install to make sure nothing gets in the line to clog them up. We are still in the build phase. Pipes are run to the equipment pad, but nothing is connected at the equipment pad yet.
The suction coming in is 2.5 inches and is coming from 2 of 4 drains at the bottom of the pool. The lines going back to the sheer descents are each 1.5 in and run independently to the equipment pad. The filter I bought above is also 1.5 inches and is rated at no more than 60 gpm. Does anyone have any experience with these and will one cover it without significant flow losses? My other option would be to use 2 of them and run a 2 inch pipe from the pump to the diverter valve and then 1.5 inch pipe on each output to an independent filter and then to the sheer descents.
Option 1 is to have 1 filter and reduce the pipe from 2 to 1.5 on the filter input, continue with 1.5 inch pipe to the diverter and then 1.5 to the descents
Option 2 is to have a 2 inch pipe to the diverter valve, step down to 1.5, have an independent filter for each sheer descent, and keep 1.5 down stream.
