Setup the waterfall with Pentair Easy Touch
Jimrahbe
18,762
Bedford, TX
Daniel,
I would not use your pool pump to drain the pool.. when you drain shut off the pool pump.
I would use a cheap sump pump.. or just use a garden hose and gravity... Like when you used to steal gas out of your neighbor's car.. :mrgreen:
This time a year, in AZ, it is not a good idea to drain a lot of water and allow the pool to dry.
You could do repeated small drains and then refill, but that will take even more water.
Reactions: pandan74
pandan74
Active member
May 16, 2020
29
Daniel,
Thank you Jim,
That was my plan to have several small drains/refills. Thankfully my pool is higher that the wash (that's how Arizonans call dry rivers) so the gravity should do the job.
Thanks again!
Daniel
