I cant find a spot where i can read up on programming my swcg and VS pump. I installed it no problem, and installed the new VS pump. what I want to do now is get fancy and have the pump running slower when I don't need chlorine generated.
Im using a mechanical timer that I just leave on 24 hours now, and manually turn the pump off at night, or just turn it down to a low setting. Can I run everything based on the pump speed, or will the SWCG go into error state from low flow and not recover when I call for the pump to give enough flow to generate chlorine?
Also, when I run the pump on low rpm, then turn it up, there is definitely air getting trapped in my filter housing. i can hear air going through the heater for a while, it eventually clears, or I can just open the pressure valve on top of the filter to make quick work. This is fine, but I really got the new equipment to have it be more automated.
