Hi, I moved into a house last year with an AquaLink RS and OneTouch panel. From the start, the OneTouch was flakey, completely turning off randomly. I was able to unplug/replug it and get a few minutes of use out of it to configure my settings. This year, it is completely unusable and just stays on the "Firmware" screen when plugging it in.
It's a long run from the indoor panel to the computer so I figured the wiring was probably messed up somewhere. I took the OneTouch out to the computer and wired it right next to it. Same issue.
I'm fine using my previously saved settings, but the clock appears to be off (lights don't come on until 10pm). Any way to set the time directly at the computer? Or a cheap alternative controller I can plug in to get it going this year without replacing the entire computer. I have the manual and there is no mention of this capability but hoping there may be some diagnostic mode/button combo someone knows about.
Attached photos of the computer and panel (when it was working).
Thanks
Thanks
