I have an Easytouch with a screenlogic protocol adaptor. I'd like to set it up so:
1. When the P button is pressed on the easy touch, the pool heater runs and the inteliflo amps up to 3000 RPM so guests/my wife have an easy way to turn the heat on and off (impossible with my goals?)
2. Forgetting the P button thing, how can I schedule the pump to run without heat for 6-12 hours per day WHILE using the chlorinator at 2000k RPM WHILE still allowing a separate schedule for heating at 3000k RPM.
The issues:
1. The chlorinator only runs when the pool circuit is on, not an Aux or Feature circuit
2. Heat settings can only be selected from the Pool Circuit and Spa circuits, not any others
The fact that the chlorinator is only powered through the pool circuit and scheduling heating can only be through the pool circuit and that you can't alter pump speed with scheduling make this way more complicated than it needs to be. Or maybe I'm making it more complicated lol.
The issues:
