- Nov 12, 2017
- 12,636
- Plaster
- Pentair Intellichlor IC-40
OK, feeling a little better about the number of cams I have! There always seems to be one more spot I just can't quite see. I'm having good luck with PTZ cams, that allows me to look around. I have one on my pool, which I can zoom in close enough to see pebbles in the deep end, water level on the edge tiles, my vac at work, etc. Great while away. I have one in opposite corners outside, so between the two I can see all four sides of my house and yard. Then another on the front door, and several inside. I've gotten quite dependent on them.I have the Ring doorbell up front because it's easy, has good notification options, and a fisheye lens for great viewing. Then I have 12 hard-wired cameras from two different systems (Lorex and Night Owl) that I have projected to my wide screen TVs in the Livingroom. We watch virtually all angles of our property while we're awake. But that's the key ... while awake. And even if I see someone, they will probably conceal their face. But between the physical presence of cameras and the warning stickers/signs I have with them, they do get attention. I went with hard-wired cameras for reliability. Now that we have all these cameras, I can't ever imagine not having a surveillance system. They also have apps so I can watch our property when I'm away or wherever I travel.
I could set-up my hard-wired system notifications to my phone like my Ring, but that can be a nuisance unless you really adjust the motion settings well. We also have floodlights (some always on, others motion) and Beware of Dog signs for our six dogs that provide an additional barriers. Right now you mention you are concerned about the equipment area which could be monitored by one camera, but you might consider any other areas you want to monitor as well before you make your final selection. Angles, distance, power reliability, night/day viewing, etc will all play a factor. Cameras ... they are addicting.
Check out this YouTuber. He has a great channel of comparisons for just about every make/model out there.
For all things tech in my house I avoid batteries and wireless/wi-fi whenever I can. All the cams are hardwired. Most of them POE (power over ethernet), which really simplifies installation. Granted, not as simple as a battery-operated wi-fi cam, but simple in terms of hardwiring.
I've also got a lock on my breaker box, which faces outdoors. It's an unfortunate location. It's good from a safety standpoint, especially because I have PV solar. As linemen working in the neighborhood would need emergency access to the solar breaker. But awful in terms of security, as a simple flip of a switch would bring all my security to its knees. So I lock the breaker box door. Something to consider for you all looking to improve your security.
Let's face it, you can't make a residential property bad-guy-proof. But you can make your house less inviting than the neighbors'...
