I'm seeking to build a small rectangular pool (max 12' x 24') in Austin Texas this year. The deck and coping will be about 250 sqft total. The pool will be ~5' from the house, ~5' from an existing 16'x16' covered patio, and the other two sides of the pool will be 1' wide coping elevated 12-24" out of the natural slope of the backyard.
Because the deep end will be a retaining wall above the natural grade, I am planning to put the automatic pool cover will be on the shallow/entry side of the pool.
My dream is a seamless half-offset subway pattern of natural stone tiles (travertine, bluestone or similar) that flows from the house over the cover well and into the coping - see my attached Excel mockup. I've done a lot of research here, Reddit, and Google images, and I've seen a few pictures of what I am looking for, but no build threads. For the pool cover, the stone would be on top of metal trays with L brackets, so it can be R&R'd when need be for service of the cover. Obviously, it will be more labor versus other types of cover lids, but I'm okay with that. FWIW, I'm leaning toward a Hydramatic cover so the hydraulic pump and electrical can be installed remotely, reducing the service required for the cover.
I worry my dream will turn into a nightmare of failure, delays, finger-pointing, and disappointment trying to get all the dimensions perfect and everything implemented as intended between a lot of subcontractors, no matter how good my GC is. IE despite my micromanagement, the deck/pours will be off by enough that the end result is wonky/wavy and 5 figures down the drain versus doing a basic stone coping and concrete deck.
I'd love your thoughts on:
- Am I setting myself up for failure trying to achieve perfect cohesion of tiling across a deck, auto cover well, and coping? IE is the reason my concept is rarely executed is that it's only a good idea in theory?
- Anyone have a trouble/regret putting their autocover under the entry to their pool? Given that I'll only have 10-12' span for the cover, I am fairly confident that enough brackets + metal trays like this fellow TFPer did last year will work for me, but I fear I'll have to micromanage the build process to get it right.
- How do you drain rainwater from travertine decks that are between a structure and the pool? Do you slope the concrete or sand under the travertine toward a couple of small grates that flow out to french drains in my yard? Or do you just slope the deck into the pool and use a pump to remove the water from on top of the cover?
- For the skimmers, do you recommend the metal trays that you install stone into? Or just bare stone with a hole cut out to use a tool to lift it?
