"Borates can help minimize pH rise in the cell." Must try adding a good dose of boric acid. I guess it will also help drop the pH without having to constantly add HCl. There is also a supplimental Astral liquid chlorine and HCl dosing system with ORP to keep the chlorine level up and the pH down (seawater is high pH). This pool is shallow, about 100k litres, heated to 28C and has a 40g/hr SWG running 24/7. It also needs 15L of liquid chlorine per week and other chlorine suppliments weekly. I do what I can to minimize the seawater circulation (very little sucking from the infinity tank) but with ferry boat wake waves washing into the pool occationally there is only so much I can do. As far as water balance readings are concerned I just use strips. Hardness is off the charts as would be expected. Like I say, the alkalinity is quite low even though the pH is aroung 7.8. Weekly chemicals I add are: Phosphate remover, Calstop (in the balance tank), Waterco Perox (every 3-4 weeks into the pool), Stabiliser (keep a low to moderate level), Benzo algaecide (lots of dark algae constanly trying to grow in the hoirizontal tile grout), black algae treatment (90% hypochlorinte), 5 x Chlorine tablets in the balance tank (minimal circulation throught the pool), HCl & liquid chlorine in the dosing reservoirs. It's insane.
