Have a new Pentair equipment setup and SL2 install. SL2 air temperature is consistently incorrect. After calibrating in Screen Connect, it will appear correct for a few minutes before regressing back to an incorrect reading. How to fix this?
If using a Pentair heat pump, should the water sensor connect to WATER or SOLAR on the EasyTouch board?
