Reading through these forums its been mentioned to use Schedule 40 PVC and avoid DWV for above ground pool plumbing. But what if something is both DWV and Schedule 40 (see links bellow)? Could these be used?
www.acehardware.com
www.acehardware.com
Charlotte Pipe Schedule 40 PVC DWV Pipe 2 in. D X 10 ft. L Plain End 280 psi Mfr# PVC 07200 0600 - Ace Hardware
PVC Schedule 40 Pipe is dual marked and can be used in DWV and pressure applications. Gradual sloping fittings are used for DWV applications. Sharply angled pressure fittings must be used for pressure. PVC Schedule 40 is highly durable, with high tensile.Find the PIPE PVC SCH40 2X10' at Ace.
Charlotte Pipe Schedule 40 2 in. Hub X 2 in. D Hub PVC Elbow 1 pk Mfr# PVC003001000 - Ace Hardware
PVC DWV fittings are for drain, waste and vent purposes. They are used in gravity-fed waste elimination systems and are for Non-Pressure systems where temperatures will not exceed 140° F. PVC is lightweight and easy to install. They require no special tools for cutting, and be installed with...
