Hi,
First off, I apologize if I'm posting this in the wrong forum.... please let me know if I did and I'll happily move it. This one sounded like the most appropriate to me?
Does anyone have any suggestions about how to remove white scale from my pool liner?
Before jumping to "lower the water and scrub with xyz..." the scale I'm talking about is on the bottom of the pool so it's not possible to "lower and scrub".
For reference:
- Pool is a vinyl liner, in-ground, about 60,000L (25,000 gal), 8ft deep end about 3-6" shallow end
- I keep the water temperature between 78-84degF
- I'm meticulous about water balance (hardness = 220-250, alkalinity = 100-110, pH = 7.4-7.8, CYA = 40) as measured with a Taylor K2006 kit weekly
- It's a salt-water pool, salt level is about 3200 (what the Jandy SWG reports)
- No metals that I've seen on test results from the pool store (I can't test for metals)
I've had the kit and been keeping the balance well monitored for about 3 years now.
I'm not sure how this scale formed, pool is about 5 years old and I noticed this scale at the beginning of last year just after I converted to SWG. Doesn't seem to have gotten worse since then but it's not getting better either.
I do use BioGuard Stain/Scale Prevent, though doesn't seem to do much (750ml per month). That and a bit of blue clarifier and Banish algaecide (100mL of each weekly) is all I add to the pool regularly besides balancing chemicals. To keep things balanced, I use Muriatic Acid to lower the pH (about 500mL/week), cheapest Alkalinity booster I can find, and Balance Pack 300 to boost calcium when I need to though this year the alkalinity and hardness seem to be very stable so haven't had to add much at all of those since I opened it in the spring.
I've attached a few pictures to show what I'm talking about. It's really apparent around the seams of the liner, for some reason the scale doesn't form on the seams. Some spots are worse than others, like at the bottom of the stairs. Brushing doesn't seem to do anything.
Is there anything I can add to the water to dissolve this? Being a vinyl pool, I can't lower the water enough to scrub it with muriatic acid or any other cleaner so I "think" the only way to get rid of it would be to add something to the water to dissolve it?
Any thoughts/opinions/input very much welcome!
Thanks...
DoC
For reference:
Thanks...
DoC
