- Jun 18, 2019
- 577
- Plaster
- Pentair Intellichlor IC-60
Hi team,
I'm now in my second season with a new pool build. Details are in my signature. I know early on, pH rise was expected with new plaster, and I also know SWGs add hydrogen off-gassing which increases pH. Now that I've fired the chlorinator up for the season and paying more attention to my pool, I am adding more acid than I expected. I just wanted to get an idea if I'm in the ballpark or not as I still feel I'm adding more acid than I expected to.
First, here's my chemistry break down from about a week ago, chlorine and pH are tested daily:
FC - 5
CC - 0
pH - 7.8 - 8.0
TA - 70
CH - 575
CYA - 70
Salt - 3600
Water Temp - ~70
CSI - -0.24
SWG run time right now is about 3.5-4 hours (6 hours pump at 60%), our weather and sun has been all over the place so this has been a moving target recently.
I'm playing with acid strategies, but I'm basically daily adding ~16 oz. of 31.45% MA to maintain what I can best tell is a daily 0.2 pH rise. It seems to be about the same whether I'm doing 8.0 -> 7.8 daily or 7.8 -> 7.6. It's worth noting, I'm dropping the acid directly into the deep end around where the main drains are. Due to the pool design, all my returns are on the infinity edge side and I only have access to one return on the shallow side near my swim up bar. I do stir up the water after acid delivery, and one of my water features runs for 10 minutes shortly after and spills over right into where I put the acid. Typically if I retest within an hour, I'll see lowered pH pretty well distributed at all corners of the pool.
Using the off season and some extended travel (SWG off) as reference, I feel like my pool likes to relatively quickly rise to 8.0 then still relatively quickly to 8.15 - 8.2 pH and can then quite slowly creep after that. I've never seen it go over that, but it's RARE I ever let it get that far. The few week long trips I've done, my neighbor will use my digital pH meter (well calibrated Apera AI1311) which seems consistent with my Taylor red drop test (so 4-5 days might be the longest I've gone without MA being added). If I recall on one of these trips, I left the house with the pool at 7.5 and then 5 days later my neighbor said the pH was 8.15, but I can't recall and that was in December.
So this basically puts me at a gallon per week of MA now, and I anticipate doubling SWG run times in Summer plus the added aeration of near daily swimming. I'd love to avoid having to do this daily, and last Summer I was at times doing 28 oz every other day and maintaining larger swings. I intended to add IntelliPh, but new guidance says it's not really compatible with an IC60, and I don't want to downgrade to a 40 as peak Summer uses a pretty high SWG %.
Finally, my water features only run 10 minutes a day just to keep things circulated.
I read of other people who add MA once a week (even with SWG+plaster), and I guess I was hoping for that now that the plaster has cured. I think one outstanding variable I have is a lot of pool surface area, and all of it is well above ground and gets way above average wind. We've had some windy days in the past month, but the last few haven't been so windy and it's more or less the same. That said, even when it's not windy, I live on a canyon that seemingly always has a gentle breeze and there's nothing to help block the pool from that (no trees, fences, buildings, etc).
Looking for sanity checks. If it's 4 gallons of MA a month in Summer for the rest of eternity, so be it, but I'd feel better knowing this is normal.
FC - 5
CC - 0
pH - 7.8 - 8.0
TA - 70
CH - 575
CYA - 70
Salt - 3600
Water Temp - ~70
CSI - -0.24
