I'm trying to determine the optimal settings for both economy and effective filtration with my variable-speed pump.
My sand filter specs show:
- filtration area of 1.92 sq. ft.
- filtration gpm/sq. ft. = 20 gpm
- filtration flow rate of 38 gpm (i.e., 20 x 1.92)
- Should I consider 38 gpm the maximum advisable flow rate for this filter?
- Should I assume that flow rates below 38 gpm could result in better filtration?
- Is there a minimum flow rate below which filtration would be ineffective? (There's no such number in the specs.)
- Can I determine an optimal filtration flow rate, somewhere between that high of 38 gpm and a minimum effective flow?
