- May 3, 2014
- 63,121
- Fiberglass
- Pentair Intellichlor IC-40
OK -- right off, your CH is very high. You will have scale very soon and it will be very difficult to prevent. If you plan to add salt, I would do a complete water exchange first.
You need to learn about CSI. It is calculated by PoolMath. Keeping it around 0 is preferred. We in the southwest desert deal with high CH and TA fill water.
Your FC is also quite low when using the FC/CYA chart. I assume your CC is not 2. Can you confirm that?
