Our Pool: 15,000 galons Spa: 778 galonsI am installing a Jandy AquaPure 1400 for my 15k gal pool. The electrical is very minimum to do. If you remove your UV system it may require a little plumbing modification. I will have the SWCG connected to the iAquaLink Automation.
Currently my salt level is 2800ppm and that is just via using liquid chlorine (which has salt in it) and I have not had any issues with Texas flagstone.
It is best to go SWCG - good luck.
Current Equipment in contract:
Filter System: Jandy CL580 Cartridge Filter Pool Pump (s): Jandy VSSHP 2.7 E Pump; Jandy 1.65 Electronic Controls: Aqualink RS6 with web smart phone connectivity Sanitization Equipment: In line Chlorinator; Paramount ultra UV sanitation Heater: Jandy JXI 400nk natural gas Air Blower: Jandy 2hp Pool
