Hello,
I'm new to the forum and just started testing the pool myself. I have been using the local pool stores for the past 4 months, but noticed some white flakes all over the bottom of the pool and so I order a K2006 Test kit to take things under control myself.
The pool color is nice, typically i've had to add about a quart of Muratic Acid every week or so to lower the pH, some stabilizer, etc. One time the pool store had me add 7lb of calcium hardness and I think that is what caused my issues, but looking for some advise. My readings are as follows:
FC - 1
CC -.5
PH 7.8
TA - 160
CH - 600-650
CYA - 60
I wasn't sure what the white flakes that settle on the bottom were, wasn't sure if it was left over stabilizer that didn't dissolve or the calcium hardness that I added. I purchased the Dolphin robot with the fine filters and it vacuums it all up, but it does come back, so it's not a one time thing, but I think Calcium scaling?
The pool is new (4 months).
Today, I put in enough acid to drop the PH to 7.0, but not sure how I'm going to try an aerate the pool. Any tips on that? Also based on the CH, do I need to drain some of the pool to get it back in order? If so, any easy way to do that?
Thanks for any tips or advise.
Regards,
Josh
FC - 1
CC -.5
PH 7.8
TA - 160
CH - 600-650
CYA - 60
Regards,
Josh
