- Apr 12, 2016
- 662
- Fiberglass
- Pentair Intellichlor IC-40
Its been ordered, I think it gets here tomorrow, where should I keep the level?You have no cya-
Around 30ppm - it only takes a small amount so measure carefully as to not overshoot your target. Use the sock method just like in the pool.Its been ordered, I think it gets here tomorrow, where should I keep the level?
You lost me with the sock method.Around 30ppm - it only takes a small amount so measure carefully as to not overshoot your target. Use the sock method just like in the pool.
You add the cya granules to a sockYou lost me with the sock method.
Interesting, seems all I ever see is the trichlor stuff, even with the little tabs. So trichlor is ok for the pool but not the tub?You add the cya granules to a sockor skimmer sock, tie a knot in it, hang it in front of a return , squeeze the sock to dissolve the granules. This happens pretty quickly in a hot tub because the water is hot.
This method is the recommended way to add granular cya to your pool as well.
Tiny amounts for a spa can be a little hard to measure which is why most people use dichlor instead. I have had my tub for 5 years & I am just now on my 3rd 1# container of dichlor.
The hotter temps of a spa make cya degrade more quickly so using dichlor every now & then is an easy way to replenish it. I use a little every couple weeks for this purpose . I keep my tub 104*
Yes - it is too hot in the tub (& closed up) for the trichlor.Interesting, seems all I ever see is the trichlor stuff, even with the little tabs. So trichlor is ok for the pool but not the tub?
So you use this along with your SWG, when and how much do you use?Yes - it is too hot in the tub (& closed up) for the trichlor.
Here’s what I use - they used to have the spa selection brand in 1# containers for $10 but have switched over to hth in bigger containers now
HTH Spa Care Clear Chlorinating Sanitizer for Spa & Hot Tubs, 2.25 lbs. (Pool Chemicals)
HTH Spa Care Clear Chlorinating Sanitizer for Spa & Hot Tubs, 2.25 lbs. (Pool Chemicals) - Walmart.com
There are several brands- just make sure it’s 99% dichlor
Leisure time is another common one
I just useSo you use this along with your SWG, when and how much do you use?
