Salt level 3600 last week and 4000 today! Causes?
Ok able to take top pipe off with special type of grip pliers recommended for job but I could not undo the lower piple and started to strip the coupling device. Now I guess I need to have a lesson on unscrewing these things
NanoMeters??
Reactions: JamesW
You shouldn’t use nor need pliers. The o rings will seal if you tighten them strongly by hand. Lube them up with red magic lube or similar non petroleum substitute. If you find a union is particularly tight use gloves or rags around it to protect your hands when tightening/loosening. Unfortunately too many times channel locks get used and that can chew up the unions and or break them.
Unfortunately I gave one of the unions a real haircut and lost about half of the spokes. Then I tightened by hand and just a little more with the filter wrench. Functional still but cosmetically now ugly. I think I can just buy a new nut if I am not mistaken.
The part number is U11=200ps. If I am correct I can slide it back, remove a c-clip, and slide if off. Is that correct?
Unfortunately I gave one of the unions a real haircut and lost about half of the spokes. Then I tightened by hand and just a little more with the filter wrench. Functional still but cosmetically now ugly. I think I can just by a new nut if I am not mistaken.
Yes should be the case. Although if the nut is sealing fine in spite of it being ugly don’t invite trouble unless you’re really OCD. 🤣 Strap wrenches work better than a filter wrench - won’t ever destroy the spokes.
Reactions: william13
Bit ocd but I can be talked down from it. Someone had really tightened that thing to no end.
Nothing is worse for an ocd person with a pool than creating a drip or leak by preemptively trying to stop a non existent one, or inducing one while fixing aesthetics that are otherwise mechanically fine. Worry about it when it’s time for the new filter. Inevitably one simple thing will lead to 10 more less simple things. Our friend Murphy has a law about such things. 😝
Can I use acetone nail polish remover to clean exterior of old pvc pipe I am about to cut or do I need to run to home depot....again!
What needs cleaning? The only thing I've ever cleaned from pvc was if it fell and got dirty. I wiped it clean with a rag and got to gluing.
Primer will clean the PVC pipe.
Ir is the PVC pipe painted?
PVC DWV question. Thank you for that link. I noticed DWV discussed in it. I have a 2 inch drain hose that will go on a 1.5 inch pipe. The Jandy valve I have is 4717 with 2 inch ports. I will be reducing one of the 2 inch ports to 1.5 inch with a reducer so as to fit the 2 inch hose. Previously I was told not t buy a DWV part but I accidently did. I was thinking that if it is being used to covert a 2 inch to 1.5 inch and the 1.5 inch goes to a hole then technically its a "drain" and should be ok. Is this correct?
If it is being used on an above ground waste pipe then the pipe is not under any pressure and DWV is ok. Being above ground if it leaks it is easy to spot and replace.
