Any thoughts on Salt Generation and Ph increase?
Here is my story: I have had a swimming pool for the last 10 years. Three years ago we had decided to put an in ground pool in to replace our aging above ground. We had decided to go with a gunite pool with a marcite finish. After the completion of the pool the acid demand was a little overwhelming which was expected. We closed the pool and upon opening early in the spring I had noticed the entire deep end of the pool was stained with a slight yellowish appearance. It took the entire summer to finally come out and have them attempt a repair. Finally after a few calls of them telling me they can't fix it so I was upgraded to a Quartz finish last fall. Similar acid demand at first but currently the pool extremely stable.
At this point I am using a Biogurad product called Smart Sticks because I didn't want to convert to salt last fall with a new finish. Now I am contemplating going back to salt to eliminate the sticks and the fact that they are in the skimmer which I don't like even though they claim it's safe. I have a brand new IC-40 sitting on the shelf that was uninstalled last year due to the re-finish.
Biggest concern is creating a situation where I am constantly adding acid into the pool again. Any Thoughts????
I know that the sticks are bringing the acid level down and the Cya up.
Taylor Test Results
Ph 7.5
Alkalinity 110
Calcium Harness 230
FC 3
Cya 45
Taylor Test Results
Ph 7.5
Alkalinity 110
Calcium Harness 230
FC 3
Cya 45
